SKY+ and RGB Something wrong?
Discussion in 'Sky Digital TV Forum' started by paulmc, Jan 15, 2008.
  1. paulmc
    paulmc
    Apr 24, 2005
    68
    Something funny going on or am I just daft?.
    Scart control off, No diff between RGB and PAL
    Scart control on, Big diff between RGB and PAL
    PAL is much more sharp and brighter. I know I could up my RGB settings but dont want to as the TV is only 3 days old ( 50" Samsung Plasma)
    Scart is plugged into the right socket. It is in TV on the sky box and RBG in the telly.
  2. Warpaint
    Warpaint
    Jul 26, 2003
    603
    28
    Edinburgh
    +62
    Some TV's will not switch to RGB unless they receive a voltage on one of the scart pins (Scart Control) I believe it's pin 8
    Your TV must be one of those.
  3. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,280
    Manchester
    +763
    Pin 8 is indeed the switching pin - but you should be asking this question in the dedicated Sky section.
    (See sticky/announcement at the top of this section)
    Chris Muriel, Manchester
  4. paulmc
    paulmc
    Apr 24, 2005
    68
    Ahh sorry, easy mistake though if you just read the title.
    Anyway what is this PIN 8 all about?
    Scart control on, Big diff between RGB and PAL. PAL being much better If RGB is not switched on should the pic not be the same no matter what I select?
    How do I fix this?
    MODS Please move this topic, sorry seems I posted in wrong place:oops:
