sky and reception
Discussion in 'Sky Digital TV Forum' started by azz, Jun 25, 2004.
  1. azz
    azz
    Feb 22, 2003
    644
    28
    Nottingham
    +22
    My original sky dish is now causing problems as for some reason the signal strength and quality are less than 50% ?the wind moved it slightly but it is too far away and too dngerous to mess with as i have had an extension built.
    Well i put up a new dish on the side of my house and signal quality and strength>50% but bbc2 and itv no reception-says no signal weired!
    Any advice please?
    Azz (Ps does say on banner what should be on)
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    Well the BBC and ITV channels are on Astra 2D which can cause reception problems for people with misaligned dishes and/or a digibox/lnb conflict, I seem to recall some Panasonic digiboxes didn't like some Cambridge LNB's and there were some problems with some Grundig LNB's(or so I have read).
    Are BBC2 and the ITV channels the only ones you are having reception issues with since you could also have a problem with the LNB switching polarities and bands but they should occur on more than those few channels.
  3. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,365
    Bradford, West Yorkshire.
    +323
    Azz - which digibox do you have? - make and model number please!
    Only BBC2 missing? No others? Sure?
    Could be the digibox (depending on make & model) or the LNB.
    Fill in the missing details and I should be able to point you in the right direction.
    A. Dork
  4. azz
    azz
    Feb 22, 2003
    644
    28
    Nottingham
    +22
    Ive looked through sky and yes you are right the odd channel is missing
    eg bbc2 itv ary cbbc etc
    The box is an old panasonic box-gold coloured (5years old)before the new silver one. Sorry i am not at home and do not know the model number
    So you think i should change the LNB?
    Azz
  5. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,365
    +323
    If it's the gold one it's a DSB30. Highly unlikely to be the box in that case.
    Change the LNB. Chances are it's a 'Cambridge' one. Should be OK then.
    Hope this helps.
    A. Dork
  6. azz
    azz
    Feb 22, 2003
    644
    28
    Nottingham
    +22
    Its definitely not the box as the old dish does have the channels when used through this box but the signal strength and quality are <50%.
    How much should i pay for a LNB?
    Azz
  7. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,365
    +323
  8. azz
    azz
    Feb 22, 2003
    644
    28
    Nottingham
    +22
    Well just an update,
    Was about to buy a LNB after this weekend but decided to watch tennis and blow me down all missing channels back.
    ? problem was at skys end
    ?poltergiest
    Thanks all
    Azz
    :hiya:
  9. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,365
    +323
    Wait 'til it rains again. ;)
    A. Dork
  10. paulryan
    paulryan
    Sep 2, 2002
    47
    Kent
    I upgraded my sky to SKY+ recently myself and all went well.
    Not sure if its co-incidence but ever since ITV has on and off been misbehaving. The picture breaks up and i get a hig shreeking noise.
    The SKY+ box is a pretty new Amstrad and the LNB a skyware quad.
    Singal strength is 50%+ for both inputs and all other channels are perfect.
    Is it the equipment or ITV signal ?
    Any help appreciated
    Paul
  11. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    The "shreeking" is a known fault on Amstrad Sky+ boxes. Get on to Sky about it.
  12. paulryan
    paulryan
    Sep 2, 2002
    47
    Kent
    Although the box is realtively new (6months) I am not the original owner
    as i bought it on ebay.
    I can try but its unlikely sky are going to be sympathetic.
    Anyone know of anyone whos successfully had anything done about this ?
  13. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Does it only shreek on ITV ? Just noticed that your signal strengths are a bit low - they should be nearer 80%. Your dish may be out of alignment.
  14. paulryan
    paulryan
    Sep 2, 2002
    47
    Kent
    Yeah, its just ITV, its happened about 3 times in a month and appears to last for a while, i end up watching another channel
    I will check my original Sony digibox running off another feed upstairs for signal strength and check it when it occurs again.
    I can always try ringing sky but thats about as exciting a prospect as going for a vasectomy (and i should know !)
  15. paulryan
    paulryan
    Sep 2, 2002
    47
    Kent
