Sky+ and Plasma displays
Discussion in 'Sky Digital TV Forum' started by MoonsSpawn, May 14, 2002.
  1. MoonsSpawn
    MoonsSpawn
    Hi all,
    I have a Panasonic 42PWD4BX plasma display and I'm using John Simms Plasma VGA converter to output SKY+ to the VGA socket.
    Anyone else notice a lot of flicker and 'shimmering' on the screen when using this method to output SKY to a plasma?
    I also get a fair amount of picture noise & colour posterisation (i.e colour staircasing) which is incredibly distracting.
    Any thoughts and comments would be most welcome.
    MoonsSpawn.
  2. MarkTaylor
    MarkTaylor
    Feb 28, 2002
    4,328
    +662
    Do you get the same problems using an S-Video connection ?
    Mark
  3. CLH
    CLH
    Apr 15, 2002
    2,159
    38
    +21
    I am positive I have this with my normal TV.
    For example, railings and bars look like they are moving from side to side.
    There does seem to be a lot of other picture noise as well.
    I don't personally think it is exclusive to plasma
  4. MoonsSpawn
    MoonsSpawn
    Yep Mark, if anything it's just a little bit worse.
    CLH: I had it hooked up to my Tosh 36" previously and Sky was immaculate. It ws almost literally like looking through a window
    on all the channels.
    Moons.
  5. MarkTaylor
    MarkTaylor
    Feb 28, 2002
    4,328
    +662
    If it is the same or worse via S-Video then that lets John's convertor box off the hook and leaves you with the Sky+ box or the plasma itself.
    If the quality was previously perfect with a CRT and the same Sky+ box then it rather points to the plasma I guess.
    Has it been calibrated at any time, or even just set up using the Avia or similar disk ?
    Mark
  6. MoonsSpawn
    MoonsSpawn
    It's not been professionally calibrated, but I have tried my best with AVIA and Video Essentials. Didn't make much difference though :(
    Moons.
  7. Steve1138
    Steve1138
    Do yourself a favour.
    Get a Silicon Image iScan pro deinterlacer. This has VGA ouput... but also improves the qualiuty of interlaced material.
    I tried it on a 42" 4D while testing it on a Loewe TV
    Definite improvement
    Steve
    (see post in TV section)
