Sky + and plasma connection
Discussion in 'Sky Digital TV Forum' started by Vish, Nov 2, 2004.
  1. Vish
    Vish
    Nov 2, 2004
    7
    Is it possible to connect my sky + box, (1st gen Pace) to my plasma using a scart to component cable (3 phono) I know that the sky + box has RGB out on the scart, but will it work?
    Vish.
  2. Blu Ray
    Blu Ray
    Jun 14, 2004
    496
    Chorley, Lancs
    +12
    You would need an RGB - component converter such as JS-Technology's one. If you don't use the Sky+ optical output to an amp already, then this box outputs the sound thru 2 phonos. It may be better to get the RGB to VGA box instead £120 vs £145, but remember you'll lose aspect switching either way I believe.
