Sky+ and Panny 50" plasma problem
Discussion in 'Plasma TVs Forum' started by delta, Nov 10, 2003.
  1. delta
    delta
    Oct 16, 2000
    469
    16
    North East Cheshire
    I was using my Sky digibox connected to my Panny plasma PC input with a syncblaster cable to enable me to have an RGB input and it worked well. Now I have changed to Sky+ and it will not work using the syncblaster. I don't know why. What alternative do I have to enable an RGB picture? The Panny S socket is used for my VCR and the component input for my DVD player. My amp is a Denon 11SR. I am totally confused and would appreciate lay-mans terms please. :rolleyes:
  2. IanM
    IanM
    Dec 17, 2002
    160
    +5
    Sorry if this sounds obvious, but are you sure that you've configured Sky+ to output RGB and that you have plugged the SCART into the correct socket? The VCR socket on the Sky+ box does not do RGB out.
    Cheers,
    Ian.
  3. delta
    delta
    Oct 16, 2000
    469
    16
    North East Cheshire
    It was so obvious we couldn't see it! You are right and I should have realised because this has happened before. The Sky+ box was set to 'PAL' and the only way I could switch it to RGB was to connect a S video lead to the plasma and access the menu that way. However we now have a picture, but no thanks to Sky. I spent some two hours chatting to various 'technical' people to try and resolve the problem and their advice ranged from, "Plasma might have switched itself to 100Hz and Sky+ only works on 50Hz", to "The only way you can get RGB to your plasma is through the optical output"!!!
    Anyway, thanks again, all is well now. I hope!
