Sky+ and Optical Out
Discussion in 'Sky Digital TV Forum' started by Nikumba, Oct 20, 2004.
  1. Nikumba
    Nikumba
    Aug 20, 2004
    231
    +9
    Does the optical out only work on the movie channels for 5.1 signal? Or does it work all the time?
    Only as as since looking at having Sky next year and using a Projector would need to find a way to pull the audio to my amp
    Nikumba
  2. screemer
    screemer
    Jul 7, 2004
    1,409
    48
    Southport
    +42
    Only on certain Sky Movie channels.
  3. Blu Ray
    Blu Ray
    Jun 14, 2004
    495
    Chorley, Lancs
    +12
    It works all the time on all channels, but it only outputs 5.1 on some movies on some movie channels, I think it says 'DD' on the EPG. Rest of the time it's just pro logic or less, whatever is broadcast.
  4. Leander
    Leander
    Mar 11, 2003
    137
    Ainsdale
    +4
    Nikumba,
    screemer is right, it only works for 5.1 on Sky movies 1,2 and 3 (and I think some very limited stuff on Disney) but if your question is does it work for all other audio then the answer is yes.
    The signal for all other channels will at best be only be in two channel although this could be in dolby pro logic form.
    Some channels will actually be in mono but in all cases you are getting a digital signal straight to your amp.
    Hope this helps
  5. Nikumba
    Nikumba
    Aug 20, 2004
    231
    +9
    Thanks, yes i did mean did it work on other channels, sorry didnt make myself clear.
    Since have the AE700 was going to put scart from sky and take the audio via optical, now i know that im happy :)
    Nikumba
