Sky+ and nagging doubts
Discussion in 'Sky Digital TV Forum' started by Faust, Feb 13, 2003.
  1. Faust
    Faust
    Dec 21, 2002
    3,230
    UK
    +669
    I have often considered getting Sky+ but have been put off by one or two nagging doubts, perhaps someone might be able to answer a couple of them. Obviously the main gripe which everyone is stuck with is the outrageous £10 monthly fee. However, a greater concern for me is the hardware. I have every confidence in most things made by Panasonic or Sony (built on years of trouble free experience). I have however no real knowledge of Pace or its products which concerns me. How reliable are the Sky+ boxes, or are there plenty of horror stories? The thought that Amstrad might get the contract for making the Sky+ box fills me with even greater dread. Do Sky have to fit Sky+ or can you ask your local independant, if so, is it more costly if you do i.e. special offers etc. Finally, is Sky+ able to do chasing playback as per my DMR E30 or is it not quite as clever as that. I find I use this very useful facility a great deal. Thanks in advance for any help you may be able to provide.
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    I've owned 2 PACE analogue videocrypt receivers and a PACE 2200 digibox and SKY+.
    Not problems with them hardware wise and I wouldn't hesitate to recommend the brand.
    There does seem to be a problem with over heating/ventilation which I think is the root cause of many of the failures reported in these forums and newsgroups.
    You can buy SKY+ yourself but it may not come complete with the Quad LNB so if you had an independent install it then you would have to source that as well on top of the premium price for a premium install. If you order from SKY then they supply the LNB either with SKY+ or within the installation price.
    Chasing playback, if you mean can it start recording a program and you can start playback whilst the rest of the program continues to be recorded then yes.
  3. kblue
    kblue
    I bought my sky+ to self-install, and the quad LNB comes in the box.
    No problems with the device at all yet - have not plugged in my VCR for a year now!!
  4. Fouldsie
    Fouldsie
    Jan 7, 2003
    10
    Swindon
    Bought Sky+ from Dixons and a local installer installed it with no problems. That was about 18 months ago and had no problems at all.
    Being able to pause live tv and watch a program that is recording a few minutes after it has started is fantastic. Never use a VCR anymore.
  5. savage
    savage
    2 boxes and a Sky + ive not had any problems since day 1 .
    I think a lot of the overheating problems are when a bigger HD is fitted
  6. plasmattack
    plasmattack
    Not sure about that. I've had two failures in two months: both boxes had the standard HD and were still always surprisingly hot (more so than my A/V amp). Sky+ boxes evidently run considerably hotter than any other piece of A/V or audio equipment I've ever owned.
  7. bobbles
    bobbles
    Sky+ is fantastic. I have never been so happy with a peice of AV
    You can pay 15p/m and have your old box relocated, great value when you consider this is 12p/m without sky+
    I know in reality it isn't, but in comparison it is
  8. danzor
    danzor
    I have had a Pace Sky+ box since day one with no hardware problems.
  9. plasmattack
    plasmattack
    As opposed to some other day? ;)
    Just how long ago was day one?
  10. danzor
    danzor
    Day one being when the Sky + first became available. I have to say the unit does run very hot and there are the occasional well documented gliches
  11. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    September 1st 2001, it was a saturday and the installer refused to climb a ladder to work on the dish another SKY installer fitted two years before which was in the same place my original analogue dish had been fitted years before.
    So I had to wait until the 5th to get mine installed :)
  12. Faust
    Faust
    Dec 21, 2002
    3,230
    UK
    +669
    Thanks for all the info so far everyone. On the picture quality side of things this is not an issue as my Panasonic DMR E30 provides picture quality the equal of Sky+. The reliability issue really does give me cause for concern though. Having looked and posted on other forums the percentage of customers on their second or third box - due to box failures, is quite worrying. If only Panasonic were producing the Sky+ boxes I would be banging on the installers door at midnight demanding an immediate install. However, all these broken Pace boxes does little to inspire me with confidence. I don't mind paying for something of quality, however, nothing irks me more than shoddy electrical goods.
  13. Just_Dabbling
    Just_Dabbling
    The only thing with picture quality your not gonna get anyone else but Sky+ is direct storage of the MPEG data.
    This causes the picture to be identical, and I don't care what anyone says, you just cannot beat that !
  14. Faust
    Faust
    Dec 21, 2002
    3,230
    UK
    +669
    What you say may well be true. However, all I would say is that for all intents and purposes and certainly for every day viewing it's hard to see any difference, even when inches away from the screen, so for me it's just fine. I don't care that much anyway, so long as the programme has been recorded I'm happy. I can sit and watch video tapes ten or more years old without caring a fig about the quality - just so long as I can see movement.
