Sky+ and HDD recorders
Discussion in 'Blu-ray & DVD Players & Recorders' started by davet010, Sep 17, 2004.
  1. davet010
    davet010
    Jul 23, 2004
    385
    +10
    I've already got a Sky+ box and a Panasonic E50, but the newer breed of HDD/recorders has me interested, mainly because of the high speed dubbing.
    If I bought, say, the Sony RDR-HX 900, could I just put it into the same place in the chain as my E50 ?
    cheers in advance
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,720
    Warwick
    +2,599
    Yes - although the Sony models wouldn't be the best choice as they lack Flexible Record. With (for example) a Panasonic E85 you could record onto the HDD using Flexible Record, edit and the high speed dub to DVD-R. With a Sony you would have to pick the closest recording mode which, if even 1 minute over 2hrs, would be at reduced resolution.
  3. CLH
    CLH
    Apr 15, 2002
    2,159
    38
    +21
    Spot on, if you (like me) record movies that are regularly over 120 minutes do not pick the Sony.
  4. davet010
    davet010
    Jul 23, 2004
    385
    +10
    Silly follow up question perhaps, but how do I move recordings from the Sky+ box to the HDD/DVD recorder ?
  5. Rasczak
    Rasczak
    Apr 3, 2002
    21,720
    Warwick
    +2,599
    You have to play them normally and record them on the DVD recorder - just as if you were transferring to VHS (only you use the RGB output instead). There is no 'file transfer' or similar from Sky+ to any DVD recorder.
  6. davet010
    davet010
    Jul 23, 2004
    385
    +10
    So burning them is actually a longer winded process than just recording them on Sky+ then burning them on my E50 ?
    Lordy !
