Sky+ and % full hard drive reading
Discussion in 'Sky Digital TV Forum' started by raydundas@bluey, Nov 23, 2004.
  1. raydundas@bluey
    raydundas@bluey
    Since the new V2. Sky+ boxes run the same firmware as the new 160GB box, if we started putting in replacement 160GB drives, would the correct capacity and available space show up on the sky digibox menu, as I heard that you had to use the progress bar as the box did not calculate the free space when you put in a bigger drive. If you see what I mean. I am shooting in the dark a bit, as it only gets installed tomorrow.
  2. johndon
    johndon
    Feb 3, 2002
    1,930
    48
    +89
    I'm sure one of the latest software upgrades solved this problem so the indicators should be correct.
    John
  3. raydundas@bluey
    raydundas@bluey
    Ah great, is there anywhere I can confirm this, as if so I will be ordering my drive tomorrow.
  4. johndon
    johndon
    Feb 3, 2002
    1,930
    48
    +89
    Try a search on the forums, it's been mentioned in previous threads.
    John
  5. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    I have a 200GB drive in my box, and the reported usage (both numerically and on the bar graph scale) is correct. The usage per item is often rounded up, because short programs can now use less than 1% of the drive.
  6. Moviebuff
    Moviebuff
    Aug 10, 2004
    2,008
    Southampton
    +233
    I've got a 250gb Maxtor in my Pace V2 with latest firmware - and all seems OK with the remaining bar also
