Sky and DVD
Discussion in 'Sky Digital TV Forum' started by cliveg, Jun 29, 2004.
  1. cliveg
    cliveg
    Nov 8, 2002
    378
    Hampshire
    +11
    Hi y'all,
    Quick question...can i plug a DVD player into the scart on the sat box, then another scart from sat box to TV? I know that normally you should plug DVD direct into TV, but I only have one RGB scart on TV.
    Thanks,
    Clive G
  2. apreading
    apreading
    Jun 28, 2004
    283
    +15
    Dont know about sat boxes - but if not you can easily get a scart splitter to allow 2 sources into one socket.
  3. DaveP
    DaveP
    That will work just fine!
    Dave
