Sky + and DVD ram
Discussion in 'Sky Digital TV Forum' started by novice2, Feb 8, 2005.
  1. novice2
    novice2
    Can anyone tell me what is the most efficient means of transferring a sky plussed programme onto a blank dvd. DO i really have to put the programme into play and then record? Surely there must be a means to directly transfer the data from Sky + to a blank dvd ram?
    Any help gratefully received
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    The data stored on Sky+ is encrypted, so it has to be played out via the decoder in the box, so the way you suggested is the only way.
  3. mikehibbert
    mikehibbert
    Jan 20, 2005
    44
    But whats the point then of the Copy function on Sky?
  4. novice2
    novice2
    I think, from reading other threads, it allows you run several sky programmes one after the other while recording onto the same DVD. A neat tool for running over night / while you are at work. Especially useful as it seems you can't record from sky to DVD and watch another sky channel at the same time. DOH!
  5. HMHB
    HMHB
    Nov 11, 2001
    25,510
    Nottinghamshire
    +3,850
    Correct, that is the main use of the copy facility. I normally wait until I've got a stack of stuff to copy and then send it all across the the hard disk on my Panasonic E85. The result is a very big file on the E85, but it can split very easily into separate programs.
    Note that you get the best quality from the tv out on the Sky+ box so I unhook my scart cable from the television and put it into the E85 when dubbing from Sky+ (the video out is not RGB)
