Sky and Dolby
Discussion in 'Sky Digital TV Forum' started by Philccfc, Nov 16, 2003.
  1. Philccfc
    Philccfc
    Can anyone tell me whether Sky transmit their programmes so that the surround sound features of my DVD system can be used ?
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    If a program was created with DS/Prologic embedded in it's stereo soundtrack then it will be present assuming a channel on SKY is broadcasting in stereo, a suitable amp with be able to use the format. Pro Logic II amps can work wonders with plain stereo soundtracks although it works better with a surround soundtrack.
    SKY+ supports DD5.1 (Well sometimes) and your DVD systems amp will need an optical input or a coaxial input (with a converter).
