Sky+ and Dolby Digital - connections
lexmark
Should I connect a home cinema system to the sky+ box via the optical or should I connect the home cinema system through the TV connections?
Thanks?
dazzlew
Only an optical connection to your amp will give you Dolby Digital 5.1.
lexmark
But I thought the decoder was in in the home cimena amp. Therefore connecting the TV to to the home cinema system via the phonos would then be decoded?
If this is not correct (which is very possible!!!), what purpose do the phono connections have?
johndon
The phono connectors will only give you stereo (or dolby surround) sound. The optical cable is a must for DD5.1
John
dazzlew
The phono cables are for carrying an analogue stereo single to either av amp or tv set. If there is a decoder in the amp or tv you can get dolby surround sound but you can't get dolby digital
johnmcf
After reading this i hooked mine up via optical and the difference in sound was like night and day.
Similar threads
