Sky + and Dolby Digital 5.1
Discussion in 'Sky Digital TV Forum' started by waterhousej, Mar 9, 2003.
  1. waterhousej
    waterhousej
    Mar 9, 2003
    30
    I am currently considering upgrading my subscription to Sky + to enable me to receive Dolby Digital 5.1 sound. The satellite dish being used is a communal dish shared by several apartments, and so the usual upgrade of the LNB required to gain the full benefits of Sky + will not be possible.
    Does anyone know if the upgrade to the LNB is required to allow the Digibox to receive Dolby Digital 5.1?
    Many thanks
    Jamie
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    A SKY+ unit will allow you to access DD5.1 via the optical link without the £10 subscription or a second LNB input.
    Be advised thay SKY+ has no autoview feature and has different remote codes compared to a standard digibox so if you have a sat control VCR it won't work(as I found out).
  3. waterhousej
    waterhousej
    Mar 9, 2003
    30
    Thank very much. Shame about Sky + not having autoview but good news that I can get Dolby Digital without the £10 extra subscription.
    Jamie
