sky + and component.
umeerw
just wandered whether the Sky + boxes have component connections or are they only scart, i'm ordering sky soon and am trying ti configure the setup in my room, cheers
U
JimmyCobra
well the fitter said yes through a convertor but they left after an hour of trying. i had sky+ on a 14 inch portable on
the living room floor via scart. and they called it a success.
seeking suitable compo from them for disconecting everything in my sig and walking away.
m488dkw
Mines a PVR1 and it has scart and s-video outputs, I use an AV receiver to convert the s-video into component for the TV
It has component RGB - do you mean the Americanised corruption of Component - Y????
choddo2006
YPrPb? The component video format that everyone in the world uses? It's not that corrupt ;)
No, SCART->component is non-trivial (have to matrix the signal so needs an active converter box) so you can't do it without spending a few quid. What is ysp1000? No SCART input on that? Sky+ does have s-video out.
I was not referring to its actual quality but to the incorrect Americanised terminology of referring to it as just "Component video" without the YPrPb
Apparently YPrPb is better than RGB for DVD playback (due to the way the DVD video is encoded but for Satellite & DTT vice versa.
Similar threads
The Best Movies and TV Shows Coming To Amazon Prime Video in August 2020. Tom's Thumbs.
