SKY+ and Component
Discussion in 'Sky Digital TV Forum' started by marky1975, Aug 20, 2005.
  1. marky1975
    marky1975
    Dec 27, 2004
    64
    romford/essex
    Hi I need Help im quite new to av stuff but here goes
    i have a panasonic pw4 plasma with RGB/COMPONET IN and tunner box which im getting rid off.
    i want to direct link from a sky + box to the pw4 in componet.
    as sky box isnt componet i have brought a RGB Scart to componet converter from keene.
    i have made sure the sky box outputs RGB and i have set the plasma to componet in.
    but nothing displays on screen apart from NO SIGINAL on the plasma screen.
    also am i right in saying that using component i dont need to use the HD,VD leads that pluged in to plasma from my tuner box that im doing away with.
    Hope some one can help
    MArk
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    have you set the plasma to recieve YUV/YPbPr Component? (instead of RGBHV)
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,119
    Rainham Essex
    +2,388
    The scart lead to the converter is plugged into the TV out scart socket on the STB isn't it? The reason I ask is that the VCR scart is composite only and therefore wont work with the RGB>YUV converter.
    YUV component leads are coloured Red, Green & Blue the same as RGB :rolleyes: , so you have got all the correct colours matched from converter to plasma? If they are wrongly connected you could get a picture, but with the colours wrong or perhaps no picture at all.
    Mark.
  4. marky1975
    marky1975
    Dec 27, 2004
    64
    romford/essex
    on the plasma you only got to options RGB or Componet.
    yes it is in the tv scart in SAT and i have RGB scart lead from sat to converter and all in the right plugs on plasma.
    im going to plug dvd straight in to plasma as i have borrowed a componet dvd player.
    will let you know the results
    thanks
  5. lscolman
    lscolman
    Jul 31, 2003
    6,749
    Tyne & Wear
    +141
    In your services, system setup, picture settings on the digibox ensure that your Video output set to RGB and not PAL.
    Cheers, Lee
  6. marky1975
    marky1975
    Dec 27, 2004
    64
    romford/essex
    dvd player does not work. that is a with a straight through component connection from dvd to plasma.
    plams is set to componet and all leads are in corect place so not got a clue what it is now
  7. marky1975
    marky1975
    Dec 27, 2004
    64
    romford/essex
    got it sorted
    the converter box from keene was broke.
    all sorted now
    thanks for everyones help
    MArk
