Sky and Cable Cabling question
Discussion in 'Cables & Switches' started by matblack, May 15, 2005.
  1. matblack
    matblack
    Jul 30, 2003
    406
    +10
    I need to run extentions for both Sky and Telewest, I have some Satalite co-ax from Wickes as I understand that you need this higher grade cable over normal co-ax. Is the same stuff suitable for both applications?
    MB
  2. matblack
    matblack
    Jul 30, 2003
    406
    +10
    Come on people, please help
    Let me rephrase the question
    I bought some 'satalite' grade co ax from Wickes will this be OK to make extention cords for SKY and TELEWEST? or do I need something different for TELEWEST
    MB
  3. davehk
    davehk
    Oct 17, 2003
    711
    28
    London
    +45
    Should be fine. I used this cable to extend my Telewest connection from downstairs front to upstairs rear of the house by going up into the roof, over and back down again. I have a cable modem at the far end - no problems.
    It's actually better than the stuff the Telewest Engineer had with him (which was not double screened).
  4. matblack
    matblack
    Jul 30, 2003
    406
    +10
    Cool thanks :)
    MB
