sky + and bbc1
Discussion in 'Sky Digital TV Forum' started by killer10971, Sep 21, 2005.
  1. killer10971
    killer10971
    Dec 29, 2004
    1,059
    +34
    the last two weeks ive set sky+ to record "medium" on bbc1 and both times the recording stops at 47min and misses off the normally important ending
    i know about manual recording and adding on to the begining and end of recordings.
    as far as i know bbc didnt overun , and on the same programme exactly the same amount of time recorded in two weeks what are the chances of that
    any ideas anyone
  2. killer10971
    killer10971
    Dec 29, 2004
    1,059
    +34
    nobody else had this????
  3. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    DO you have any padding set be a defined amount or AUTO?
    Either way the EPG can be over ridden by the now&next data, it may be that the BBC were running slightly behind and therefore the SKY+ stopped recording as the next show was triggered.
  4. killer10971
    killer10971
    Dec 29, 2004
    1,059
    +34
    i have the padding set to auto , but have no problems on other channels , and it stopped at 47 min on both weeks
    thanks for the reply
  5. smelly
    smelly
    Oct 16, 2004
    1,601
    Bristol
    +102
    I went to check my sky plus to see whether mine also stopped at 47 mins but last weeks was overiden (yes I'm that short of space!!) However on checking digiguide to see whether its repeated at all I notice that the episodes listed are ep 2, 4 (last weeks) 6 (next weeks) and then 10!!! Whats happened to the ones in between??
    I hate it when they do this - there is absoulutely no point in trying to watch the series as you miss half of it!!! :mad:
    Rant over :D
  6. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Log a complaint with the BBC. You can do it online.
  7. killer10971
    killer10971
    Dec 29, 2004
    1,059
    +34
    many thanks all
    i was just getting into it as well
    "and the real murderer is........................END OF RECORDING"
