SKY+ after installation questions
Discussion in 'Sky Digital TV Forum' started by rbecking, Oct 6, 2003.
  1. rbecking
    rbecking
    Sep 25, 2003
    I had sky+ installed yesterday just a few questions.
    Both inputs strength and quality are at about 70% is this ok?
    My telephone line is about 4 metres away from the TV but the engineer seems to have only put a 3m phone cable in so the TV won't push back now! Is it just a normal modem cable so I could buy a 5m one from anywhere?
    When I go into TV Guide the text seems to be flickering, same with the search and scan bar, and the vertical edges of this seem to be very distorted. I have Panasonic Widescreen TV and when something is in 4:3 mode and I bring up the search and scan bar it also makes the edge of the 4:3 picture distorted aswell. I am using RGB mode.
    Does the hard drive turn off when you put the box in standby?
  2. ryanos
    ryanos
    Nov 17, 2002
    266
    +3
    Anything over 50% is deemed acceptable
    I think the telephone wire is just standard
    modem cable
    Can't comment on your tv picture but sky+ on my Sony 32fx66 100hz has no faults at all. In fact the picture is greatly improved from my 5 yr old panny digibox
    Not sure if the H/D turns off but the box still records in standby you are better off leaving on your fave channel so you can utilise instant rewind and be sure to get any software updates
  3. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    The slightly bent edges occur in RGB.Yiu could stop it by reducing brightness,but you should find that normal viewing is ace,and the TV Guide will not look too bad after a few days.Maybe you have previously watched in non RGB,then its quite noticeable
