Sky+ - advice on temporary movement of equiptment
Cudwell
Hi - hope this isn't a naff question (I'm not particularly tech minded!)
I need to disconnect my TV, DVD and SKY+ box from the mains supply and temporarily move them into another room (for storage), whilst I undertake some work in the room they are normally in.
Will I be able to do this, and then put it back and plug it all back in again without creating any operating problems?
Advice welcome.
JayCee
Advice welcome.
Yes, I suggest you make a note or mark the cables as to which go where before dis-connecting them.
When you re-connect it all and switch Sky on don't be alarmed if it takes a minute or so while it "boots up"...it will do a "Searching for listings" and will go straight to the Sky welcome channel.
Nick_UK
A good tip - place all the cables coming out of the wall in a plastic bag, and tape them to the wall with masking tape. This will prevent them getting plaster or paint stuck to them.
Podcast: CES '22 TV Announcement Round-up, Plus, Most Anticipated Movies of 2022 and More...
