Sky active problem
rawowl
I wanted to view another match that sky active provided in the snooker on sky sports 2, so I pressed the red button, went to active snooker where a was met with a blue screen, I backed up then a "please wait" came up bottom right and nothing else happend. So I tried to switch sky off in any way I could. In the end I had to take the plug out before restarting :confused: tried it again and got the same thing !!!
Does it sound like a faulty box :rolleyes:
Starburst
Try other "active" services, if they work then it's more likely to have been a hiccup with the digibox software or the active system itself at their end.
rawowl
Still the same problem tonight which makes me feel there is a problem at my end . Also Paramount 2 says no signal is being received :(
Starburst
Not at home during the snooker to test it myself but just had a quick look and the s&s banner for SS3 is wrong since it's claiming Live Snooker is on but it's actually skateboards:)
Have you noticed any confusion between the EPG and the banner in regards to the snooker?
Long shot but ya never know:)
Samsung Micro LED, Mini LED, NEO QLED TVs and More: AVForums Podcast Interview
