SKY+ Activation from abroad
T
Tandoori
I live abroad and have bought a second hand SKY+ box (160gb PVR) and plan to buy a "Second hand contract" viewing card (sent to UK address). I will call SKY to activate the card with my UK mobile from abroad.
Does an unsubsidised/second hand SKY+ box have to be connected to a UK phone line to activate the viewing card and/or activate the recording function?
Any Help?
:lease:
Any Help?
:lease:
Sky customer Service have instructions not to activate any new (includes what are termed "econd hand" contracts) Sky+ or HD cards without the box having made a call back from the registered UK landline. Very occasionally people have managed to "blag" their way past this BUT not often.
ian-d
Yep, very rare for sky to activate a subscription card (note the difference between activating and pairing) without a call back first.
Remember that subscription cards can be activated by a call back only, no need for a call to sky also, so if you have a friend who's able to setup the box and card at their home on your satellite dish and do the activation, then send to you, that would work.
Alternatively go through a supplier specialising in europe, but you'll pay a premium (annual charge) for this.
T
Tandoori
Thanks. I'm trying to avoid the premium. Activation has to be done with my own box, right? Or can I use someone else's in the UK that is hooked up to a phone line, and then they call SKY with my box serial number etc.?
Your box will need the card in it calling from a UK phone number, and will need pairing by Sky with a phone call if you want any Premium channels (Movies or Sports) or Sky+.
This is why those sellers are able to charge a premium - if it was easy they wouldn't be needed.
T
Tandoori
I'm back and have sky+. Thanks to those who posted replies.
So just want to close the loop for anyone else researching how to get and activate SKY+ from abroad. First of all, if you can afford it, pay for a professional in your country to sell you and set up the whole system and subscription. I've had loads of hassles and sanity-challenging-moments getting mine set up through my own efforts. I would not do it again. But it is possible.
If you live in the UK, with a SKY+ subscription and you're moving abroad, just take it with you and get a bloke to mount your dish. Keep your subscription at your UK address.
However, I've lived abroad for ages and wanted to set sky+ up from scratch. A year ago I bought a regular (non-recording) SKY box on ebay with a freesat card, and was satisfied with the free channels. But recently I've been so busy that I wanted the record my fav shows. So I bought a second hand SKY+ box on ebay and a 4 quad LNB (the old freesat system went into another room), and bought a 'second hand contract' Sky+ subscription using my UK address. The trouble is activating the SKY+, which must be done via a phone call back from the box itself in the UK, or using an expensive device to make disguised calls from abroad. I chose the call from the UK option. On a trip back to the UK I collected the second hand box and headed for a friend's with sky. Trouble is the box was dodgy, I'd been sold a dud. After weeks of researching how to get the box, card and all activated I nearly had a nervous breakdown. (btw the advice out there is often contradictory). However, I don't give up easily, and with the clock ticking away the hours before my flight back to country x, I found another sky+ box on ebay in my locality and bought it from the seller the same day. Meanwhile I received new information (still not sure if true) from someone claiming to be knowledgeable that 1. sky+ needs 2 call backs in a row to be activated, and 2. if you activate the subscription from someone's number who already has sky+ it can screw up their subscription. I suspected this was rubbish, but I didn't want to risk my friend's subscription. Luckily he had another phone line we could use. So we went through the process of activating the card and doing the 2 call backs from the new(er) sky box. Meanwhile time of flight departure was looming close. Messages on screen said the activation was successful. Yes!! But when I checked to see if the record function worked - error message. Panic. Called sky for help, they advised various tests and then did a full system reboot. Machine would not then start up again. Sweat was pouring down my back. Another dud? And because I had bought the machine second hand they refused to help any further. Machine finally came back on, still with recoding system error. Resigned to my failure I packed up the box and flew home. My technical credibility with my spouse seriously diminished.
Determined to try again once back home, I did another last hope system reboot and hey presto it worked. I finally had recording functionality. I couldn't believe it. My son and I danced around the living room with joy.
Now waiting for the satellite engineer to come do the wiring for the second room and additional cable for the sky+ (currently just have a temporary one through window) - trouble is he's cancelled on me twice already.
So a cautionary tale, pay to avoid the hassle if you can, and/or buy from very trusted sources only.
FRANTIC FRANC
2 callbacks should always be done and it is best to leave the box switched on until the card pairs. Doing more than 2 callbacks will make no harm (in fact I sometimes do 5 or 6 on service calls.
Pairing is not always needed now as it automatically does it now but I have known it take a 12+ hours
Cheers, Franc
ian-d
Which is why companies like www.satone.tv exist :D - to provide the viewing card/digibox service for you, providing you have an installer in your country able to do the rest.
ian-d
Cheers, Franc
Never had a need for 2 callbacks unless it failed, which with Sky's callback service is often! Auto pairing has been useful, but does take a while, not good if your on the job and have to leave it 'not working' ;)
