sky+ about to be installed - what to do with old dish?
Discussion in 'Sky Digital TV Forum' started by mobione, Jan 18, 2004.
  1. mobione
    mobione
    Mini Dish about to be installed. Can I use my old Sky dish (still in situ) for anything - e.g hotbird or other satellite and channel then thru the sky+ box aswell as the min dish for sky.
    Or should I just ask the installer to dismantle the old dish?
  2. Malky1903
    Malky1903
    Jul 2, 2003
    1,908
    48
    Aberdeen
    +64
    Sky+ utilises the same dish. The LNB gets changed and an extra run of cable is installed.
  3. Gordon @ Convergent AV
    Jul 13, 2000
    13,999
    +2,803
    If it's an old analogue dish then the new Euro HD channel is broadcast from that position. You might want to keep it up for that at some point.
    I used my old one for Hotbird 13 so my wife could get French TV. It needed to be re-sighted but I just got the guy to do that when he installed the Sky Plus minidish.
    G
  4. mobione
    mobione
    Thanks gordon
    Did you hook it up thru the sky+ digibox or did you need to use another decoder?
  5. CARLOS
    CARLOS
    Feb 11, 2001
    5,953
    WEST MIDLANDS
    +1,212
    Could be wrong but i thought you needed planning permition to have two dishes on the side of the house ?
  6. Gordon @ Convergent AV
    Jul 13, 2000
    13,999
    +2,803
    I used another decoder and a card. I then chanegd it to a Technomate receiver and a suitable card.
    Gordon
  7. Attu
    Attu
    Jun 16, 2003
    809
    28
    +41
    Yup you realy need planning permition if your having two dishes on the side of your house.
    Andy
  8. Gordon @ Convergent AV
    Jul 13, 2000
    13,999
    +2,803
    Well no one told me and no-one has complained.....then again it is on the back of mine,
    G
  9. HMHB
    HMHB
    Nov 11, 2001
    25,558
    Nottinghamshire
    +3,886
    I've had 2 dishes without any problems for years
  10. Fernsehman
    Fernsehman
    You only need planning permission if somebody complains. ;)
  11. Attu
    Attu
    Jun 16, 2003
    809
    28
    +41
    Ahhhhh permission :) thats what happens if you copy/paste half of someones post without reading it through :)
    Yup i supose your right unless someone complains then there shouldnt be a problem but the Sky installers that came to me wouldnt fit 2 on the house, neither would they fit a dish to a chimney ?
    Andy
  12. iaria
    iaria
    Dec 7, 2003
    108
    16
    Crawley,West Sussex
    I have two dishes outside my front of the house, one is a sky minidish and the other is a 80 cm for Hotbird, and so far no permission
    Gerry
  13. SteveRSF
    SteveRSF
    Nov 10, 2003
    265
    I have an old analogue dish still up on the back..... as sky digital was installed on the front,so all the old cables are still in....are there any channels i can get with the old nokia box,or can i use my old sky digital box now it's been replaced with sky+
  14. Fernsehman
    Fernsehman
    Which "old nokia box" (or even Nokia, since it's a manufacturer's name)?
    If it's a reasonably modern analogue receiver, you can still receive the German channels from Astra1 at 19.2'E, plus a few others.
    See http://www.analoguesat.co.uk/
  15. mobione
    mobione
    Well tomorrow is the day.
    I'm going to ask the installer to reconnect the old dish (80cm analogue). Someone has cut the lead just as it joins the LNB. This house used to have sky before I moved here, the old owner took his minidish but left the old analogue dish and an analogue receiver. I reckon the last installer cut the cable to the analogue dish.
    Anyway I plan to have it reconnected, aligned to Hotbird and then I will buy a cheap FTA digibox ?technomatic.
    What direction is hotbird, anything specific I should ask for tomorrow?
    Thanks:D
  16. Gordon @ Convergent AV
    Jul 13, 2000
    13,999
    +2,803
    Get it pointed to Hotbird thirteen degree east and put a universal LNB on end
    Then ask for help as to what receiver to buy etc....
    G
