Sky+ 5.1 Sound
Discussion in 'Sky Digital TV Forum' started by toby, Apr 8, 2002.
  1. toby
    toby
    I've had my sky+ for quite a while now and can't live without it !
    Just one thing, on 5.1 broadcasts the sound level is around half that of a normal broadcast. Output is via a sony amp. Has anyone had this problem, or is it just me ??
    Any help would be appreicated
  2. DaveP
    DaveP
    It's a "Feature"! Everyone is affected and there is no cure:(
    DaveP
  3. toby
    toby
    Ok, thanks for that....better just get a more powerful amp !
  4. Fairzo
    Fairzo
    Apr 8, 2002
    107
    16
    Seriously considering getting Sky+ for 5.1 broadcasts as well as recording abilities. Is lack of sound level a problem as far as you're concerned? I'll be using a Sony DAVS 500 system which presently plays TV or CD's comfortably at volume 15 out of 40. DVD's need to be at around 27/40.
  5. toby
    toby
    Well, I use a separate Sony amp, and the difference between TV, DVD and 5.1 volumes required is quite big. There is still alot in reserve though, and although this is more powerful than your DAVS 500 system, I would of thought you would be OK for a normal living room.
    I don't quite know why the 5.1 sound should be so low, but I'm sure there is a good reason !? Anyone have any ideas, or have sky forgotten to turn the volume knob up ??
