sky 2nd tv
Discussion in 'Sky Digital TV Forum' started by barrykil, Jun 23, 2002.
  1. barrykil
    barrykil
    Jan 17, 2002
    2,380
    48
    +26
    hi
    need a bit of advice,would it be cheaper to run cable myself and buy extra controller and signal sender or pay sky to do the job for £85.
    need about 25mts of cable, plus where would you get extra controller and or sender to do the job.
    thanks
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    It might be cheaper and more tidy if you did the job yourself.
    The hardware and cable are not expensive these days.
    Satcure sell the TVlink style hardware and the radio based extenders that don't require a cable to the second TV.
  3. barrykil
    barrykil
    Jan 17, 2002
    2,380
    48
    +26
    thanks for the info starburst will look up satcure and give it a go, cheers
