Sky+ - 2nd TV - Picture quality problem
Discussion in 'Sky Digital TV Forum' started by gmcl, Dec 18, 2004.
  1. gmcl
    gmcl
    Dec 18, 2004
    I've just had sky+ installed and have run a coax cable to a 2nd TV from RF2. When the loft aerial is not connected, the sky picture on the 2nd TV is 1st class. Connect the aerial to the sky+ box and the sky picture on the 2nd TV is poor. Picture from the aerial Terrestial channels is fine. My TVlink works okay.
    Any suggestions, apart from pulling the aerial lead out every time I want to watch sky in the bedroom.
  2. Flimber
    Flimber
    Sep 22, 2002
    13,364
    Yorkshire
    +4,477
    Re-arrange Sky's frequency to summat else ?
    Mike.
  3. gmcl
    gmcl
    Dec 18, 2004
    Mike
    How do I change Sky's frequency - don't want to mess it up. Can you point in the right direction.
    GMcl
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    go into menu and change RF2 output Frequency to a channel not picked up by remote TV already 1-69 can find out which frequencies channels occupy if you know which transmitter you use (cant sreiously muck any thing up) try randomn numbers 13,25,46,57 normally work have to retune remote TV after each change till you get a clean signal
  5. Flimber
    Flimber
    Sep 22, 2002
    13,364
    Yorkshire
    +4,477
    Might be in the hidden service menu: Services, 4, 0, 1, Select.
    Mike.
  6. gmcl
    gmcl
    Dec 18, 2004
    Thanks for the help. Picture much better now.
