Sky+ 2LNB signal lost?
Discussion in 'Sky Digital TV Forum' started by Jack the lad, Sep 2, 2005.
  1. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    New Zealand was Nottingham
    +86
    Just a quicky. My second LNB signal is missing?
    I have swapped the LNB leads over on the back and confirmed that it isnt an LNB feed problem but a Sky+ problem.
    I have tried a system reset ( un-plug from mains, re-connect and hold the backup button) but nothing seems to happen :confused:
    my questions are:
    1. Am I not doing the reset correctly?
    2. Any ideas?
    Thanks in advance :thumbsup:
    Jack
  2. JayCee
    JayCee
    Jan 20, 2004
    22,319
    Lanarkshire
    +2,325
    These are the symptoms of a failed hard drive. :thumbsdow
  3. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    That isn't a reset Jack, but a forced software download. Try this (Press in sequence):
    Services, 4, 0, 1, Select and then choose full system reset from the menu. You will lose all your recordings though. Hope this helps :)
  4. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    +86
    Thanks for the replies :smashin:
  5. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    +86
    Just what I need :rolleyes:
    Lets hope its not :)
  6. Cynthia 7
    Cynthia 7
    Hi Jack,
    When I press Services on my Sky+ remote, and then check Signal Test, I often find that my Input 2 signal is showing no signal at all for strength or quality. When I check the Input 2 Sky box (not Sky+) on the upstairs television it is showing perfect Sky reception on whichever programme I tune it to, not the same programme as the downstairs tv. I have often wondered why this happens. Tonight it is showing good signal quality and low signal strength but sometimes it's just blank without loss of reception. I have just bought a new Sky+ box and it was also showing a blank signal sometimes.
    I'm not sure whether you mean your input 2 box has failed or one of the leads to your main Sky+ box. I hope it's not the latter.
    Is this what is happening to yours.
  7. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    +86
    Hi.
    Its the dish input 2 socket. When I try to pause/record/instant rewind I get a message say function un-available contact Sky. So could like previously mentioned be the hard drive :thumbsdow
    I will look into it more tomorrow. Might have to get a recon unit until HiDef comes out.
  8. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
  9. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    +86
    Thanks for that link :smashin:
    Any idea of approx costs?
    Or will I be better off just getting a cheapy replacement until HiDef hit next year?
  10. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Depends on what size of drive you fit. You can get an 80GB drive for about £30, and a 160GB drive for about £60. Available from Technoworld and Ebuyer If you own a Pace V1 or V2 box, you will need a security Torx #10 tool which you can get from Maplin.
  11. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    +86
    Cheers Nick :)
    I have a v2 box. Dont suppose you if you know if any of these hard drives are available from PC World do you?
    Footies on this afto :eek:
  12. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Sorry mate, I wouldn't shop at PC World if my life depended on it. You really need a computer shop, not one that thinks it is ;)
  13. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    +86
    Sorry Nick.
    Any of these any good HERE and HERE mate? :)
  14. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    +86
    Yeah i know what you mean. Its just that I have about 2 hours in which to get a drive install it :)
  15. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    They will probably both work, but no guarantees. :)
  16. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    +86
    Hey Nick.
    Managed to get the 80gb Matrox (?) from a local computer shop. £48 and works a treat. Phew, just in time for the foory :clap: :clap: :clap:
    You are a top bloke :thumbsup:
  17. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Excellent ! :smashin: You have been busy :)
  18. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    +86
    Yeah it was dead easy (following your excellent guide :thumbsup: ). Took about 10 mins. Had a bit of a nightmare getting the right bit for the screws though. In the end I modified the screw heads ;)
  19. TrevP
    TrevP
    Hi Jack,
    I had the same problem with my 3yr old Pace v1 sky+. My box was failing after every 1 -1½. In the belief it was a hard drive problem replaced existing with 80GB drive, however still no joy....eventually had a replacement (Pace v2), which is working fine and dandy
    Glad you sorted the problem !!!!! :smashin:
  20. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,079
    +86
    Cheers Trev :thumbsup:
