skip chapter in my movies
Discussion in 'Microsoft Windows' started by tim k, Jun 15, 2005.
  1. tim k
    tim k
    ive attached a pic of me viewing a dvd on hd in my movies, i cant seem to find a button that will take me to the main title menu, i just have to fast forward all the adverts, is there a way to do it?
  2. stripe
    stripe
    Apr 7, 2004
    1,291
    Scotland
    +123
    I'd love to know too.
  3. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,489
    South Derbyshire
    +198
    AnyDVD will take you straight to the main title.
  4. Rambles
    Rambles
    Jul 14, 2004
    8,479
    UK
    +1,355
    There is a DVd Menu button on the remote, or you can skip chapters by pressing skip - or is that not what you meant?
  5. tim k
    tim k
    i dont use the remote, have wireless keyboard and mouse, surely there has got to be a way to skip the ads.
  6. Slinkoff
    Slinkoff
    Oct 14, 2004
    699
    28
    +24
    not without the remote. I had similar problems until I got the remote. And as mentioned earlier AnyDVD has an option to skip ads and trailers automatically and take you straight to the title menu.
  7. tim k
    tim k
    thats crap, design fault i reckon, surely theres alot of media center users that just use the wireless keyboards, i mean thats the main picture featured on the microsoft mce site, a guy with plasma and keyboard.
  8. MikeFish
    MikeFish
    When you rip movies to your hard drive why do you keep the ads? I assume it's because you want to rip all the extras and menus. When I rip all I copy is the actual film and the DD & DTS soundtracks. Saves alot of room and means the films start straight away, ie no ads, no fbi warnings, no menus etc.
    As for the skipping, I had same problem and bought a remote. I seem to recall pressing every button on the keyboard to no effect.
  9. Slinkoff
    Slinkoff
    Oct 14, 2004
    699
    28
    +24
    the only way is you have a keyboard with multimedia buttons, the track skip button should do it. But even then you will have no ffwd or rwd, just get a remote off of ebay for £20 and save yourself some hassle, you'll find you won't really need your keyboard at all (unless you're playing games). If you have another PC on a network you can do any system admin and installs from a remote desktop session so the need for a keyboard is even less.
  10. tim k
    tim k
    slinkoff you star!! i do indeed have multimedia buttons on my keyboard, and the skip button works a treat/ :clap: :clap: :clap:
    mikefish what you said also spurred me on to look into getting rid of the ads completely, using dvd shrink i didnt realise you could re-author and chose to just have the main part of the film. ill give it a go when i get some space (I've backed up all my dvds on my 160gig hd!!)
