Does anyone have some idea for changing to newer skins and not the 3 pre-installed?
V viperhansa Standard Member Jan 25, 2010 #1 Does anyone have some idea for changing to newer skins and not the 3 pre-installed?
jerryjal Prominent Member Jan 26, 2010 #2 If i remember correctly you can download them to the head unit via the usb. Also the wallpaper is the same size as the psp ones, so just google it and you will find loads.
