size settings on amp
Discussion in 'AV Receivers & Amplifiers' started by 7 of 9, Aug 9, 2002.
  1. 7 of 9
    7 of 9
    hi everyone, i need your advice i have some old but great quality mordaunt short 10i speakers a pair for the front and a pair for the rear and a mordaunt short 10 centre speaker, frequancy response is 60 - 20hrtz they are stand mounters and are on stands, i have no sub and my amp is a marantz sr 4200 what size setting should i put the amp on.
    many thanks for all help given
  2. Jase
    Jase
    Mar 16, 2001
    10,803
    United Kingdom
    +2,693
    Depends if you have a sub or not. If you have no sub then set the Front Left & Right to LARGE all others to SMALL, Bass to MAIN.
    If you have a sub then set them all to SMALL, ALL BASS to SUB. Or you can set the Front Left & Right to Large, all others to SMALL, BASS to BOTH.
    Just depends what you prefer.
  3. 7 of 9
    7 of 9
    thanx for your help i am very greatful.
