size of tv
freddefred
hi my cinema room is 3 mtrx3mtr sitting viewing from 280mm tv will b wall mounted
would a 75 inch be okay watch a lot of action sport samsung qled thanks
EndlessWaves
Do you mean 280cm rather than 280mm?
If you do mean 280mm then 75" is far too large. I'd not want to go for anything above 40" if you're less than a foot from the screen, and 32" is probably better.
