Size of screen suitable for both 4:3 and 16:9
Discussion in 'Projectors, Screens & Video Processors' started by ralphot, Mar 1, 2005.
  1. ralphot
    ralphot
    Feb 24, 2005
    38
    Hi guys (and girls?)
    I am in the process of making a screen for my proj now.
    As older films are in the 4:3 size and the newer in 16:9 I wonder
    if the width is changing when the format changes?
    That is, if I adjust the proj exactly for the 4:3 size.
    I don't think that is the case but I am not sure.
    If not I would make a screen that is 4:3 and 1,9 meter times
    1,43 meter and mask top and bottom when looking at 16:9 movies.
    The other way around could not work I guess as the 4:3 pic will
    be off the top and bottom in that case.
    Am I rigth or am I wrong?
    Regards,
    Ralph
  2. cosmic023
    cosmic023
    Feb 15, 2003
    1,375
    48
    Somerset
    +88
    Hi Ralph,
    Well it depends on how much material in either format you watch the most ??
    If you watch more 16:9 material than 4:3 then a 16:9 would work, otherwise have a 4:3 screen and make some form of velvet covered board to attach above & below to mask it into a 16:9 screen ??
    I tend to watch more 16:9 material over 4:3 material, so i went for a 16:9 sized screen.
    Hope this helps in your choice ??
    Cosmic023
  3. ralphot
    ralphot
    Feb 24, 2005
    38
    Will go for a 4:3 screen 190 X 143 cm to get approx 80" 16:9
    and approx 96 4:3 and masking top and bottom when 16:9.
    Thanks Cosmic023
  4. Prehjan
    Prehjan
    hi fellows...i am on the same boat too with my barco 801s...just wondering one thing..will an 8" diagonaly screen work in the same way??
    thanks
    Martin
