Size And Placement Question
Discussion in 'Home Cinema Speakers' started by Tardis, May 21, 2005.
  1. Tardis
    Tardis
    Nov 13, 2003
    480
    28
    +31
    Out of curiosity, is it NOT recommended to have the same make and model rear left and right surround speakers as the front left and right speakers in bookshelf size in 5.1?
    What about 6.1 and 7.1 providing the front and rear centre(s) are of the same make and model?
    Would the sound be any better or worse and is there anyone using this kind of set-up?
    TIA
    Tardis.
  2. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    The optimum type of rear speaker depends to a large extent on room layout as in some rooms direct radiating speakers will work well but in others with less room behind the seating position bipole speakers on the rear or side walls will work better.
    Multichannel music on DVDA or SACD is mastered for optimum reproduction with all five speakers equidistant away from the listener and I would guess that five identical speakers would be optimum - if you have the right room layout which I would guess most of us don't.
  3. Tardis
    Tardis
    Nov 13, 2003
    480
    28
    +31
    Thanks for the info Ian J. :thumbsup:
