Sixth Speaker
Discussion in 'Home Cinema Speakers' started by rudlands, Mar 24, 2006.
  1. rudlands
    rudlands
    I have recently brought a Denon HT 550SD systems which has the SYS-A3L speaker system. It comes as a 5.1 surround package but the amp has the capability to go 6.1 - all I need is another speaker. However Denon have discontinued the speakers (sc-a3l satellite speakers).
    I am fairly new to all this - does anyone have any recomendations for a suitable substitute?
    Thanks!
    Sam
  2. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    Anything that you like the look of should be fine as it's only a rear effects spreaker i.e. a small centre should be OK. If you can get it from the same make/ family as your rears so much the better.
