Six feet Under, seasons 1-4 - £17.99 @ HMV
Discussion in 'Shopping, Deals, Discounts & Bargains' started by danjaq, Mar 8, 2006.
  1. danjaq
    danjaq
    Dec 12, 2004
    965
    +19
    As title suggests.
    Especially better with the e-vouchers!
  2. krish
    krish
    Mar 8, 2005
    36,211
    Astral Crescent, Zoovroozlechester, Betelgeuse V
    +17,070
  3. danjaq
    danjaq
    Dec 12, 2004
    965
    +19
    Well, I cheated - someone else on another forum mentioned it!
    If you buy all 4, then you'd get £10 off the order ... which is nice :)
    --- All seasons appear to be non-anormorphic 4:3. Is this poor? ---
  4. krish
    krish
    Mar 8, 2005
    36,211
    +17,070
    True for seasons 1 & 2 unfortunately!!
    Quite suprising for a quality HBO product that wasn't broadcast that way
  5. danjaq
    danjaq
    Dec 12, 2004
    965
    +19
    Thanks! Just checked and S3 onwards is 16:9.
  6. rhythmslave
    rhythmslave
    Nov 21, 2005
    263
    +61
    When I search for Six Feet Under it comes up with two versions for each season, with different release dates. I assume the newer ones are re-released to coincide with the new season, but are there any differences between the two? Have they changed the packaging again?
  7. danjaq
    danjaq
    Dec 12, 2004
    965
    +19
    This would be interesting to know as well - maybe this will be a studio offer too.
  8. krish
    krish
    Mar 8, 2005
    36,211
    +17,070
    I doubt it... I was only looking at season 4, but noted that it was the same cat no on both release dates; Amazon et al just show the original release date on all SFUs
    also noticed different labels... WHV (= Warner Home Video) for the initial release, and HMV for the "re-issue" - HMV exclusive packaging perhaps??? (I opted for the WHV)
  9. danjaq
    danjaq
    Dec 12, 2004
    965
    +19
    I've emailed HMV asking this question - will report their reply back here.
  10. Jim Morrison
    Jim Morrison
    Feb 9, 2003
    2,142
    +258
    Best TV Show Ever - FACT!
    Great deal at £17.99 each season...i've long since had them all but anyone fancying a dabble, i can't recommend this series highly enough - it's abolutely brilliant. Hmmm...not long until season 5 hits the shelves!
  11. hughesy
    hughesy
    Jan 22, 2005
    848
    Irish in Oz
    +13
    Where do u get the e-vouchers???
  12. krish
    krish
    Mar 8, 2005
    36,211
    +17,070
    from the HMV thread:
  13. hughesy
    hughesy
    Jan 22, 2005
    848
    Irish in Oz
    +13
    Does anyone know if the 5th series is the final series???
  14. vince379
    vince379
    Feb 4, 2003
    419
    28
    +30
    I was under the impression that the first two seasons were filmed with 4:3 in mind. Certainly when they were aired in the UK they were 4:3. I assume this was the same for the US otherwise they would have released it ws on dvd.
    Yes season 5 is the final season.
  15. hughesy
    hughesy
    Jan 22, 2005
    848
    Irish in Oz
    +13
    Would any of ye not opt for the 5 season box set... at 119... £100 after voucher???
  16. danjaq
    danjaq
    Dec 12, 2004
    965
    +19
    Okay, as promised, reply from HMV regarding the 'duplicate titles':
    Thank you for your email.
    I am very sorry for the confusion regarding this series, you are perfectly correct, we are running two versions of each on our site at present.
    This is due to a technical problem.
    I have contacted our web team and the details should be amended within the next 24 hours.
    In the meantime, if you should wish to order the items it will be fine if you select the ones that have 'Your saving' next to them, when you add the item/s to basket please check that the price is £17.99 or £34.99 if it is for the Season 5 , if it is £17.99 or £34.99 in basket then that is the price you will pay for the items.
    I do apologise for the confusion and inconvenience caused.
    Please do not hesitate to contact me should you require further assistance.
    Kind regards
    Anna Grazier
    Customer service
    HMV.co.uk
  17. danjaq
    danjaq
    Dec 12, 2004
    965
    +19
    Yup! just done that now - for £99. Makes sence as I need all seasons and it makes season 5 cheaper! Especially cheaper with 5% cashback from a referral site (which I may not be allowed to mention here). Sod's law, in a few weeks the boxset will be cheaper somewhere else! :)
  18. marge
    marge
    Jul 18, 2005
    350
    +25
    I ordered that with my £20 e-voucher for £89.99, when they first put it on the site it was £109.99.
    £99 is still good.
  19. danjaq
    danjaq
    Dec 12, 2004
    965
    +19
    That's a pain, when was that price there?!
  20. marge
    marge
    Jul 18, 2005
    350
    +25
    Just checked my order confirmation, I ordered it on 18/01/06.
  21. danjaq
    danjaq
    Dec 12, 2004
    965
    +19
    Ah well, like I said - prices will always fluctuate - shame though. I guess it is not cheaper elsewhere (for the boxset) .. ?
  22. marge
    marge
    Jul 18, 2005
    350
    +25
    HMV is the cheapest at the moment with the £20 off, Amazon are the cheapest (pre-voucher HMV) @ £111.99. play £127.99 :eek:
    Still a very good deal at HMV and the box design is brilliant.
  23. hughesy
    hughesy
    Jan 22, 2005
    848
    Irish in Oz
    +13
    Have to agree, that's what i was thinking... i think its worth the extra few £:cool:
  24. hughesy
    hughesy
    Jan 22, 2005
    848
    Irish in Oz
    +13
    Bought the 5 season boxset.... Thanks fror the headsup and vouchers!!!
