southpaw220
Established Member
- Joined
- Oct 1, 2011
- Messages
- 121
- Reaction score
- 5
- Points
- 32
I’ve built a SIPs shed room and am now turning attention to the interior. I seem to have blown my budget so I’m now focused on getting finished rather than making perfect. My thoughts had been to add 25mm rockwool and 15mm acoustic plaster to help out with insulation - is that a good balance between price / performance ?
Another idea I had today was to place strips of rubber mat like below in between the internal batten and plasterboard. Any benefit in doing this or would it be a waste of money?
cheers
M20 Rubber Sheets
M20 Rubber sheets as an acoustic mat designed to be installed as part of an acoustic wall lining. The product allows a good level of airborne sound reduction without losing significant depth on the room where the product is installed.
www.soundinsulationstore.co.uk
cheers
