Sinking 42" plasma into brick chimney breast
Discussion in 'Home Cinema Building DIY' started by BDCSTENG GARETH, Jul 12, 2005.
  1. BDCSTENG GARETH
    BDCSTENG GARETH
    Jul 5, 2005
    347
    Sutton, Surrey
    +8
    I have already wall mounted my TH42PWD6BX onto my chimney breast, and blasted holes on front and side to hide all cables. I am starting a new shift pattern as of next week, which leaves me at home 2 days a week without any... interuptions....
    I was planning to take the panel down next week and cut all cables and install wall plate for tidy termination. I have now decided that I would like the look of sinking the panel into the wall so the screen is almost flush with the wall. Has anyone attempted this?
    From the experience with my 2ft, 25mm SDS drill, I know that the depth of the brickwork is not just the narrow side of 1 brick. actually, I think the depth is at least 6-8".
    Any pointers or opinions pls.
    Gareth. :lease:
  2. banners
    banners
    Jun 26, 2002
    439
    nottingham
    +16
    I've not tried anything like that before! :eek:
    Personally I'd be inclined to build the rest of the wall up/out to make the screen flush, using studding and plasterboard.
    On the plus side you'd have plenty of space between the existing wall and the new wall to hide cables etc.
    HTH & good luck
    Steve
  3. BDCSTENG GARETH
    BDCSTENG GARETH
    Jul 5, 2005
    347
    Sutton, Surrey
    +8
    I had thought of that but space is sort of at a premiem in my front room. I have a fireplace and mantlepiece, which the centre speaker sits on nicely. I was planning to take the brick about 4" back and an area about 3" larger in all directions of the plasma. I thought It would look quite cool is the edges of the recess were champhered at a nice 45o angle...
    I'll post a photo of the setup at the moment and maybe I could get some creative support?
    Gareth.
    Gareth.
  4. pwes
    pwes
  5. scooby do
    scooby do
    Dec 11, 2002
    1,765
    48
    +37
    Watch out, chimneys weigh tonnes. You need to be very careful when messing around with them. I know someone "who had a go" and the whole thing fell through, including the next door neighbours. They weren't trying a flushmount, were planning on removing the chimneys but it all happened a bit quick for them!!!!!
  6. BDCSTENG GARETH
    BDCSTENG GARETH
    Jul 5, 2005
    347
    Sutton, Surrey
    +8
    Pwes... That looks cool! Is that a lintle you put in there? Where did you get it from?
    Here is a link to a new thread with some pics. The fire is electric, and has fake flew pipe... Good this as all the cables (inc sky) go through the void!
    http://www.avforums.com/forums/showthread.php?t=226699
    I think i'm going remove the handes aswell from my plasma cos they just look ugly!
    cheers guys,
    Gareth.
  7. pwes
    pwes
    The lintel is just a chunk of steel from the warehouse at work which we use to suspend BIG projectors from, so pretty darn strong. Once in, you can mess with anything below to your hearts content !
  8. randallnhopkirk
    randallnhopkirk
    I would suggest that you don't box it in tight, ie. to the rear leave some space for ventilation and a route for the warmed air to escape. The reason is that although plasmas lose a great deal of heat through radiation from the front, the key electronics boards are at the back and you don't want them heating up too much.
  9. mikeaitch
    mikeaitch
    Apr 21, 2001
    1,583
    Stoke
    +55
    I second that
    Make sure you leave plenty of ventilation, and don't forget to put as many types of cable into the recess to make it future proof even if you don't need them now.!
    I didn't think I'd need a HDMI lead as there were so few bits of kit that had them 2 years ago- now look....Sky HD, Xbox360/PS3, DVD, scalers, etc etc
    Mine was built using simple studwork, the only tricky part is the new coving around the top
    You might want to put some led backlighting behind there - who needs Ambilight??
    here's some pics
    http://img.photobucket.com/albums/v105/mikeaitch/plasma/IMG_0207.jpg
    http://img.photobucket.com/albums/v105/mikeaitch/plasma/df023864.jpg
    http://img.photobucket.com/albums/v105/mikeaitch/plasma/e608874b.jpg
    No apologies for showing the pic of Ms Knightley :D
