Single wire bi wire
toastedone
I have a new set of speakers that can be bi wired if I was to single wire them would it be to HF or LF port. Also would bi wiring them make much difference.
Rock Danger
No. If they were bi amped it could. You'll find the speaker terminals are currently bridged together so it doesn't matter what pair of terminals you use.
PSM1
Common convention would normally say put them in the LF posts but as above I do not think it will matter which you use. Biwiring will give no sound improvements over a decent sized single cable.
toastedone
Many thanks
