Single system for HiFi and AV
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by chee, Aug 4, 2004.
  1. chee
    chee
    I have a seperate HiFi and AV system set up in the same room at home.
    I am wondering if I should replace both with a single system.
    My current HiFi system consists of a Krell KAV-300i amplifier, Micromega Stage 2 CD player and Sonus Faber Grand Piano speakers.
    My AV system consists of a Kenwood KC-Z1 and KM-Z1 pre and power amp and Boston Accoustics THX speakers.
    I listen to music about 4 times as much as I watch DVDs. What would be a good system to replace this. I would probably want to retain the Sonus Faber speakers.
  2. nikyzf
    nikyzf
    Do you want/need surround sound for DVDs? If not, have you considered using your excellent hi-fi for movies? 2 excellent channels vs. 5 not-so-good?
  3. chee
    chee
    I think it is more involving if DVDs are watched in surround sound. I feel that with 2 channels a lot of the effects are missed out, no matter how good your system is.
  4. nikyzf
    nikyzf
    Fair enough, just checking on how important the surround effects are to you :D
  5. 337GUS
    337GUS
    Nov 1, 2000
    753
    NE Scotland
    +38
    Chee
    How about replacing the Krell 300/Kenwoods/Bostons and having Sonus Faber speakers all round with the Krell Showcase Processor and Power Amp?
    What DVD player do you use?
    Gus
  6. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Take a look at Lowrider's system.
    I heard it and sounds great!
    Also with Sonus Faber speakers.
  7. chee
    chee
    Hi Gus,
    Yes, I condidered that, but I'm afraid it is more than I can afford. I have an old Sony DVP S7000, which I will also change as well if I change my current system.
  8. Rob.Screene
    Rob.Screene
    Sep 29, 2001
    1,313
    Berks, England
    +140
    Tag AV32R surround processor as a pre-amp in to your Krell integrated, plus 3-channel+ amp for center/surrounds. You could use the AV amp in multi-channel input bypass at first, then add a dedicated power-amp say to bi-amp center and surrounds/surround rear if you feel the multi-channel usage is worth it.
    I'm getting nice results from a Tag AV32R 192 7.1EX and Linn power-amps and speakers for the front pair. Sublime music and movies from one system.
    regards,
    Rob.
