single speaker stand?
S
samuraijack
Does anyone know / recommend where I could get a single speaker stand to sit the centre speaker of my system on?
Not looking for anything fancy - just has to be approx 30 - 40 cm cm in height, be able to support a fairly small, light (1 - 2 kg) speaker. Preferably in silver and with as small a base as possible.
Cheers for any help, all I can find are pairs of stands!
mrg
try putting a post in the for sale forum asking if anyone has one or wants to go halfs on a pair
B
bobbypunk
Try a dealer for someone like optimum who may be able to order as one item, the only reason i suggest that particular company is they have been good for all other odd requests in the past (Not tha you're request is odd).
OnTheFly
Here is the answer to all your problems.
I was after a single speaker stand so I contacted Atacama Audio direct to see if they would sell a single stand. They would. When I suggested 400 mm was a little short they offered to make it 500 mm for an extra £10. Excellent. It arrived two days later.
The model I purchased was the SL
Podcast: LG C1 Review, Apple Lossless & Dolby Atmos @ no cost, Sennheiser IE900 review + more
