Single shelf rack
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by 3sgte_power, Jun 16, 2005.
  1. 3sgte_power
    3sgte_power
    Jun 7, 2005
    1,178
    48
    Coventry
    +76
    I am after a nice single shelf rack (a little table if you want to call it that) for my Linn Classik. Is there anything, which is appropriate? Even something like a nice shelf and storage for CDs below or something would be nice.
    Look forward to opinions.
  2. bobbypunk
    bobbypunk
    go to www.optimum2000.com as you choose pole heights and shelf numbers on most of their racks.
    For a really nice looking stand to match look at www.spectral-moebel.de in the beamer section specifically the c35
    If you are on a budget there is a few by www.alphasondesigns.co.uk like the AG54 in the aragon range but this isn't a patch on the spectral!
  3. 3sgte_power
    3sgte_power
    Jun 7, 2005
    1,178
    48
    Coventry
    +76
    Thanks...i just purchased a Spectral Twin Light Stand. Looks the business. Cost was £129.99. Much cheaper then what greenapple were charging for a column type stand.
