since installing rollup2 remote is super sensitive
JonLeach
Established Member
as title, since installing rollup 2 the remote is too sensitive to use. for instance pressing any key more often than not sends a double key press. i.e. hot changing to the last used channel on tv with the ok button sends you back to the program you were just watching.
anyone else had this.
Jon
Slinkoff
Established Member
You might have debounce disabled. Check the value for EnableDebounce in the following key:
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\HidIr\Remotes\745a17a0-74d3-11d0-b6fe-00a0c90f57da
Make sure it's set to 1.
JonLeach
Established Member
cheers for that dont know where you found that one. BUT ............
checked both currentcontrolset and controlset001 both set to 1.
ay ideas as its really annoying now. may need t roll i back!!
jon
Is 8K TV dead? Philips OLED+907, Pioneer LX505 AVR plus B&W 700 S3 Reviews & Visit + AV/HiFi News
