Sin City Premiere Photos
Discussion in 'Photography Forums' started by johntaylor, Jun 2, 2005.
  1. johntaylor
    johntaylor
    If anyones interested here are some photos from the premiere of Sin City at Leicester Sq. I didn't get to see the movie unfortunately, just one of the red carpet photographers. I shot these in B&W, on a D1H (would have used a D1x but its just not fast enough for this situation) I didn't use my own flash for these pics. If you use a slow enough shutter speed you pick up ths flashes from all the other cameras which gives good lighting effects. Its a very hit and miss affair though! I took about 600 frames and these 10 were the only ones to catch someone elses flash. I was tyring to get the premiere pics to look a bit like the film stills, not a particulary easy task. I wasnt actually commisioned by anyone that night, if I had been and had just sent them these photos, I would have been sacked!
  2. DJW
    DJW
    Aug 29, 2002
    1,062
    36
    Good shots John & thanks for the tip about using others flash :smashin: . I actually prefer the lighting effect it gives.
  3. johntaylor
    johntaylor
    Cheers Dave, the technique is unfortunately only really usable to pro photographers. There has to be s*!t loads of flashguns going off to be able to get someone elses flash. But this is how it works. Set shutter speed to about 1/30 sec, anything else is going to render most of your photos blurred, especially on 70-200mm lens. Set yout aperture to F5.6 as this is generally the flash output that most of the other photographers will be using. I use maual focus, get your pic composed and in focus as someone stands still for about 5 secs! then just blast away, keep your finger on the shutter button! when its done, check your pics, probabaly about 99% will be unusable! hopefully 1 or 2 will have registered another flash.
    Similar results are now being obtained by wireless flash systems, but in a situation like a film premiere its very dificult to set up a wireless flash.
    John
  4. seany
    seany
    May 1, 2003
    2,997
    61
    Manchester city
    Thanks for sharing those john.
    Realise that on occations where you need the money shot, a zoom can be a life safer. Have you ever used primes for nights where you've caught without a flash/not workin.
    How does the D1H handle high iso's?
    Thanks for sharing
  5. johntaylor
    johntaylor
    Hi seany, when I was doing Sin City I was not actually employed by anyone on the night, that's the only reason why i shot it as i did. I had no client to worry about and was only working to sell shots via syndication, if I was working on commision I would have played it safe and shot everything with flash.
    I dont generally use prime lenses myself, (apart from 300mm) I use 2 bodies, D1X, D1H, with flashguns SB80DX powered by Quantum battery, Nikon 28-80 f2.8 and Nikon 70-200 f2.8 VR. These lenses are are pretty sharp, probably not as sharp as primes, but not far of and yes they are very handy. When shooting a premiere youre supposed to get full lengths of the ladies in their dresses, half length and tight head shots, so you need the versatility of a zoom.
    I dont usually get caught out with a broken flash, it has happened, but ive got two so i can just revert to using one body.
    The D1H I have never personally used beyond 800 ISO for a job. I will allways try and get round having to use it beyond that ISO setting by some means. Its not great at 800 and after that its pretty bad.
