Simultaneous SPDIF and analogue out
Discussion in 'Desktop & Laptop Computers Forum' started by starfire, Nov 23, 2004.
  1. starfire
    starfire
    Jun 15, 2004
    364
    +24
    Does anyone know of a soundcard that can both pass-thru AC3/DTS to the SPDIF for decoding by an external decoder/amp AND simultaneously output a stereo downmix to analogue (phono) outputs?
    I would like this as sometimes I watch films via my projector with the full 5.1 surround system going, and other times via the TV only and having to switch manually by going into the property page for the audio codec isn't very wife friendly :)
    Or has anyone come up with a good solution to the above that can be achieved via remote control? I run everything via a myHTPC frontend and Zoomplayer.
    Thanks for any ideas,
    Simon.
  2. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    The RME cards do this.
  3. cwick
    cwick
    Feb 4, 2002
    2,207
    Reading
    +95
    As does my MAudio Audiophile 24/96. Can only confirm for PCM though - don't use DD/DTS pass thru.
  4. starfire
    starfire
    Jun 15, 2004
    364
    +24
    Thanks, I will try and find more information about these cards, but I have a workaround for the time being: using regedit to update a registry flag for my dvd codec which switches SPDIF off/on, which when driven from my frontend has a high WAF factor :thumbsup:
  5. stlic
    stlic
    Feb 17, 2004
    733
    +15
    Hey starfire just wondering which codec you use and the reg keys? The nforce board audio I used to have in my HTPC had no problems doing simulataneus analogue and spdif PCM out.. but the Live! 5.1 I've got at the moment only allows one option.
    I have been looking for a way to change the spdif setting in windows sound control panel using a shorcut but have come up enpty handed thus far.
  6. starfire
    starfire
    Jun 15, 2004
    364
    +24
    I'm using the sonic cinemaster dvd decoder pack, can't give you the registry entries as they're at home and I'm at work.
    But ultimately, with most of this windows stuff when you change the options in a control panel or something it just updates a registry key, so simply record the registry before and after making the change and you'll soon find out what key it is.
