Shady Deal
Just got a freeview Telly with digital Tuner built in. I get a bit of colour bleed from it and would like to try my old skybox on it. (Other sources like RGB and component are fine, no colour bleed)
My Skybox is a silver Panasonic one (Model no ends with 30 I think) and it has not been used for the past 6-8 months, but I still have the card.
a) If I connect it up will I be able to see the FTA channels to check what the pictures like.
b) I thought I read on here that if you leave the card in the box for 24-48 hours Sky will activate it again for the FTV channels. (If not, where do I get a FTV card from)
c) Can someone confirm that you can pass RGB signals in via VCR scart and then out via TV scart?
Thanks for your time
