orangepeel
Established Member
Morning all.
So after about 10 years with the current system we are looking at a rejig. The way we use AV has changed so we want to maintain quality but simplify use and the set up. Our current set up with how much we use each element is in brackets below. We are open to replacing any element but happy to keep if there is no need to change.
Kit and usage:
Priorities:
Separate the sources completely -
Or
Keep all audio running through amp
Concerns
We don't need help with replacement TV at this point. It's about getting the audio set up right for now and into the future.
I hope you can make some sense out of that - I'm struggling to! My gut is to separate the systems but concerned I ill end up buying another sub for the soundbar. Sorry for the long post, just though I'd throw it all on the page.
Thanks in advance for any help!
O.
Kit and usage:
- Marantz receiver Sr6300. No phono stage, has a and broken remote. (heavy)
- Sony TV KDL-32V4000. Will replace in Jan. (heavy)
- Humax HDR- FOX T2 (light)
- Sonos connect (heavy)
- Pro-ject essential II & phono box. Ground interference issue need to sort if keeping the marantz av amp. (medium)
- Chromecast (heavy)
- Android TV box (light)
- Speakers x4 MA radius 90, MA radius 250 centre, Wharfdale SW250 (heavy)
Priorities:
- Simplification
- Easy switching between TV, Sonos, vinyl audio. The missus gets p*ssed of with switching from this and that and different volume controls.
- Improve music SQ from sonos.
- Decent SQ for TV movies ect. Lot of stuff streamed with mixed audio quality anyway.
- Reduce number of speakers
- Less remotes
- Buy decent soundbar and go back to stereo Hi-fi for vinyl and Sonos so no switching needed.
- Buy new/used speakers (£400)
- Poss new/used stereo amp (£300).
- New TV (£500).
- Buy a Soundbar (unsure of cost)
Or
- Keep Amp,
- sort phono issue out
- new stereo speakers, keep centre speaker.
- New TV.
- Sort remote control out maybe go decent all in one.
Concerns
- Do I need to replace the amp?
- Is it good enough anyway for music?
- Will I miss the centre channel and sub if just have stereo speakers / soundbar?
- Will I end up buying a soundbar bar sub?
- Will keeping an amp for TV and music audio still feel a faff for the missus?
O.
