Simple VGA Switcher
Discussion in 'Cables & Switches' started by Shakey_Jake33, Aug 25, 2005.
  1. Shakey_Jake33
    Shakey_Jake33
    Sorry for the n00bness of this topic, I'm basically looking for a simple VGA switcher. 4 or so inputs, one output. PC, Dreamcast, XBox360 and a spare, going into my TV. Maybe even some form of amplification to avoid signal loss (unless you think one is not needed).
    Everywhere I look for one seem to just sell KVM boxes, with all the extra keyboard connectors which I don't really need.
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,418
    The Borders
    +2,591
    Shakey_Jake33
    A couple of 'low cost' (around £200) options to consider:
    Zektor HDS4 - very high quality 4:1 video switcher (uses RCA connectors not VGA connectors) and offers you IR control plus audio switching for Digital audio.
    The HDS4 can also be used as 4:1 YUV + Stereo or Digital audio switch or a 1:4 RGBHV or YUV Distribution amp.
    See http://www.zektor.com/hds4/index.html
    Kramer Electronics VP-41 - a simple mechanical 4:1 switch with no IR or Audio options.
    See http://www.kramerelectronics.com/indexes/item.asp?desc=228
    If you want line drivers on a per Output basis you may have to consider adding them to any line you see a signal drop on or look at a MUCH more costly solution that's designed to drive long cable runs.
    See http://www.autopatch.com/series_1y/1y16/index.html
    Best regards
    Joe
