Simple(?) Sync link question
Discussion in 'TAG McLaren Audio Owners' Forum' started by Inotrope, Jul 8, 2005.
  1. Inotrope
    Inotrope
    Dec 23, 2004
    687
    Nottingham
    +44
    I have a CDT20R T2L and a DVD32FLR into a AV32R DP bp 192, and I wish to use the sync link with BOTH sources, to save faffing around at the back of the units, can I use a phono split plug on the AV32R and plug both sources in?
    Has anyone else tried this?
    thanks mark
  2. DanielB
    DanielB
    May 27, 2004
    158
    Switzerland
    +12
    Hi Mark
    simply "daisy-chain" it. Use the input and output socket on the FLR as stated in the user manual
    Regards
    Daniel
  3. Inotrope
    Inotrope
    Dec 23, 2004
    687
    Nottingham
    +44
    I mean the Tag T2L sync link, rather than the TagTronic communications link.
  4. PhilB1234
    PhilB1234
    It's still the same...
    e.g.
    AV32 >Sync cable>DVD32 >Sync cable>CDT20
    Connecting in series like this allows both CDT and DVD32 to use the Sync-link (although the other unit needs to be in standby I believe)
  5. DanielB
    DanielB
    May 27, 2004
    158
    Switzerland
    +12
    I mean the T2L sync link too.
  6. PhilB1234
    PhilB1234
    ...Don't forget to 'enable' the Sync Link in the AV32's menu for each source.
  7. Inotrope
    Inotrope
    Dec 23, 2004
    687
    Nottingham
    +44
    D'oh!
    I completely forgot about the IN/OUT on the FLR!
    Thanks, mark
