Simple REL Quake question.
Discussion in 'Subwoofers' started by Bristol Pete, Aug 25, 2003.
  1. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,577
    Bristol.
    +321
    Moving my REL quake.
    I was just wondering which option ensures that the sub does the power, not leaving it to the amp..
    Can anyone recall if its option 1 or option 2 on the four way switch at the rear?
    Put the manual somewhere safe, to safe!
    thanks,
    Cap
  2. magking
    magking
    Jan 6, 2001
    378
    Norway
    The sub does the power all the time.
    The switch decides if you're using bassmanagement on the reciever or on the sub. 1 uses the crossover on the sub 2 bypasses the crossover I think, I have a REL Q400 manual somewhere, but I i think you can find this at the REL homepage, look here.
  3. eddiea
    eddiea
    You can dowload the Manual here: http://www.rel.net/products/UserManualQRange.pdf
