Simple Question re: Buzzing
Discussion in 'Plasma TVs' started by Snubber, Jul 5, 2005.
  1. Snubber
    Snubber
    Jun 11, 2005
    60
    Plymouth
    +3
    Hi all,
    Have a Panasonic 42PE50B for just over two weeks. After day three I noticed a buzzing coming from the rear of the set (definitely did not have it at first) - sounds like a circuitry/PSU buzz. I accept that all plasmas will buzz to a certain degree, however (here's the question).......should you be able to hear the buzzing from 12ft away (as my wife and I can) during quiet scenes and when on mute? The buzzing is worse during bright scenes and when in dynamic mode.
    My opinion is definitely not since it really does interfere with my enjoyment of the televison. I can't see how it can be deemed 'fit for purpose' if it makes so much noise.
    I would really like to hear other peoples opinion as it will hopefully provide extra weight when I go back to retailer and seek a replacement.
    Thanks in advance.
  2. Mep
    Mep
    Dec 25, 2004
    9,579
    Surrey
    +474
    i agree with you....I can't hear either of mine unless i get real close to them.
  3. MrNPG
    MrNPG
    Apr 13, 2005
    714
    Poole, Dorset
    +44
    The buzz on mine is barely audible from 12ft away. I need to get pretty close to it for me to hear it and it certainly doesn't effect my viewing "pleasure".
  4. nickeddle
    nickeddle
    Feb 2, 2005
    352
    North Yorks Moors National Park
    +10
    I have the Pio xde and I can only hear any buz if I put my ear to the back of the panel with the sound off
